Step 3: forces export
Introduction
This section explains how to export a Computation of surface magnetic forces on rotating machine imported mesh.
It is available through the menu  or through the icon
                  Force computation  |
Export for Nastran and export for OptiStruct
The exports for Nastran and for OptiStruct allows exporting forces harmonics into a Nastran format file.
In the export box, user has to specify:
- The computation name
 - The number of harmonics to export
- “empty” to export all harmonics
 - n first harmonics (n to specify)
- Force unit
 - File name .BULK / .FEM
Export for HyperMesh
The export for HyperMesh allows exporting the forces into a file in HyperMesh format. In HyperMesh, it is possible to choose at the beginning a working profile which can be OptiStruct or Nastran.
For the export for HyperMesh, user has more options:
- Computation name
 - The number of elements in depth is not to enter in this case
 - The export format: Nastran/OptiStruct
 - The file name
 - The force evolution type: static/temporal/frequency
- Static forces: forces exported on one time step in magnetic transient (in this case, the computation should be done only on the interesting step, otherwise the first step is taken)
- The force unit
 - Advanced options:
- Number of harmonics (if empty, all harmonics are exported)
 - DLOAD card ID: this ID allows distinguishing the exports done on the same project (especially when solving with multi-physical parameters) to import all files correctly in HyperMesh. By default (DLOAD=0), the computation ID is attributed, but user can choose it manually in this option.
 - Simple or double precision: it defines the exported values precision.
Export into a data file
It is also possible to export the static or temporal forces into a .dat file
