Adjustment: meshing by shading (on the close faces in 3D)
Introduction
Shading improves the meshing of close faces.
Principle
Shading permits the user to take into account the proximity between two geometric objects to define the mesh.
Notion of shading
When two geometric objects (generally two non-adjoining volumes), are close to one another, shading will influence the size of the nodes in function at the proximity of the two entities.
In the example below, volumes (2) and (3) are very close to volume (1) but they do not touch. The zones where the volumes are almost in contact will be meshed in a denser manner.
Aided mesh
For each 3D project, the software creates an aided_shadowface instance dedicated to the Aided mesh.
