Constraints
Introduction
Constraints | Required informations |
Constraints on 2D faces volume |
Double symmetry constraint |
In this case, only one of both axis must be defined,
choose between (1;0) for X axis or (0;1) for Y axis.
Symmetry constraint |
In this case, the direction of the symmetry axis is
(0.5;0.5)
Constraint on a response |
Constraint given by a Compose function |
