Optimization options
Introduction
In the data tree of Flux the node Solver > Optimization > Optimization Options allows the user to set the different options for the optimization algorithm.
The table in the next section summarizes all the optimization options.
| Option | Required informations |
| Optimization tolerance (in percent) |  Stops the optimization process when the objective value varies
                                        (d) less than the tolerance value between two
                                    iterations.Default value = 0.5%![]()  |
| Maximum number of iterations |  Stops the optimization process when the maximum number of
                                iterations is reached if the convergence was not met.Default
                                    value = 30![]()  |
| Move limit | Define an area where the nodes can move, this area may be defined
                                    by:
| Sensbilities filter | Define an area where the nodes will move in an average direction
                                composed of each node directions, this area may be defined as:
| Tolerance for the barriers |  This tolerance is used to control how close the lines of the
                                final design can be. 0.5 meaning half of a mesh size.Default
                                    value = 0.1![]()  |
| Open a Flux with the final design when optimization is done |
