Flux sketcher: correction tools
Introduction
Several tools of correction are proposed to the user by the Flux sketcher. These tools allow rendering a description in accordance with Flux specificities. They can also be used after a CAD import on which corrections must be made for compatibility with Flux.
The corrections can be made :
  • locally, on a part of the geometry
  • globally over the assembly of the geometry
Each of these functions is described in the following sections.
Contents
