Designate the tool or surface(s) and on your model for the bottom pad.
        The bottom pad is attached to the bottom die with a spring
            or hydraulic cushion. The bottom pad grips the blank against the top die in order to
            maintain the proper positioning and avoid distortion of the blank during a forming
            operation. The configuration also involves selecting the bottom die to which the bottom
            pad attaches.
                Select an operation, then from the tool set that appears, select the
                        Bottom Pad.
                On the guide bar, choose Part or
                        Surfaces.
                If you choose Part, on the model, select an option from
                    the table below based on your desired result, and then click to confirm.
                If you choose Surfaces, on the model, select the
                    surface(s) you want to designate as the bottom pad, and then click to
                    confirm.
                    Note: If you modify the blank thickness, you must reconfigure the tools created
                        by offset.
                In the microdialog, click the option to apply a Force or
                    maintain a Gap. For force, type in a value for the
                    Initial Force and the Final Force, or click the Calculate the Medium
                        Force button
                    Note: The gap value is the material thickness plus 20%.
                Define the stroke, velocity, and Coulomb friction coefficient.
                        In the microdialog, to set the stroke value to the closed position of
                            the tools, select
. To specify a value, select the pencil tool
, type in a value, and press Enter.
                            Note: If you define the stroke value to be larger than the
                                auto-calculated or closed position, the open position of the tool
                                automatically repositions to match the stroke value to prevent a
                                collision with the bottom die.
                        To define the Coulomb friction coefficient, in the microdialog, enter a
                            value next to the icon
                        Click to confirm.
                On the guide bar, click Attach Tool. The preselected
                    bottom die is highlighted. Click to confirm or select a different bottom
                    die.
                Click to confirm the configuration of the bottom pad.
