Designate the tool or surface(s) and on your model for the top binder and the part to
which the binder attaches.
The top binder provides a holding surface above the blank
in order to grip the perimeter of blank against the bottom die during the forming
operation.
Select an operation, then from the tool set that appears, select the
Top Binder.
On the guide bar, choose Part or
Surfaces.
If you choose Part, on the model, select an option from
the table below based on your desired result, and then click to confirm.
If you choose Surfaces, on the model, select the
surface(s) you want to designate as the top binder, and then click to
confirm.
Note: If you modify the blank thickness, you must reconfigure the tools created
by offset.
In the microdialog, click the option to apply a Force or
maintain a Gap. For force, type in a value or click the
Calculate the Medium Force
button.
Note: The gap value is the material thickness plus 20%.
Define the stroke, velocity, and Coulomb friction coefficient.
In the microdialog, to set the stroke value to the closed position of
the tools, select
. To specify a value, select the pencil tool
, type in a value, and press Enter.
Note: If you define the stroke value to be larger than the
auto-calculated or closed position, the open position of the tool
automatically repositions to match the stroke value to prevent a
collision with the bottom die.
To define the Coulomb friction coefficient, in the microdialog, enter a
value next to the icon
Click to confirm.
