addTable()
Add a table to the report.
Usage
addTable( table, caption = None, justify = None,
ref = None, colsWidths = None, border = True )Parameters
- table (list)
- A two dimensional list containing the table rows and columns data.
- caption (string)
- Caption of the table.
- justify (string)
- Table justification. Valid values are flushleft, flushright and center.
- ref (string)
- Label of the table for reference.
- colsWidths (list)
- List of column widths in centimeter.
- border (boolean)
- If True draw table borders.
Return Value
None
presId = -1
massId = -1
for i in range( nOsiVars ):
name = adb.get( "osiVarName", i )
if name == "pressure": presId = i
if name == "mass_flux": massId = i
nOsfs = adb.get( "nOsfs" )
inletId = -1
for i in range(nOsfs):
name = adb.get( "osfName", i )
if name == "inflow": inletId = i
pres = adb.get( "osiValues", inletId, presId )
mass = adb.get( "osiValues", inletId, massId )
mpData= [ ("Pressure Drop (Pa)", "Mass Flux (Kg/sec)" ) ]
for i in range(len(pres)):
mpData.append( ("%.2f" % pres[i], "%.2f" % mass[i]) )
rep.addTable( mpData, "Fan performance", "center", "tab:mp" )
