ASSIGN
Assigns a value to a variable.
AcuSolve Command
ASSIGN {parameters}
Qualifier
This command has no qualifier.
- variable or var (string) [no default]
- Variable name.
- value (real) [=0]
- Value assigned to the variable.
This functional command assigns a value to a variable to be used in expressions defining integer, real or array parameters. Details can be found at Parameter Operators and Functions.
ASSIGN {
variable = MPH
value = 1609.344 / 3600 # mile/hr --> m/sec
NODAL_BOUNDARY_CONDITION( "inflow x-velocity" ) {
variable = x_velocity
type = constant
constant_value = 60 * MPH
The variable names are case insensitive; therefore, the double quotes that are used for string parameters may be omitted, as in the above example.
