RESTART
Restarts from a previously solved problem.
AcuSolve Command
RESTART {parameters}
Qualifier
This command has no qualifier.
- from_problem or problem (string) [no default]
- Name of the problem from which to restart. If not specified, the name of the current problem is used.
- from_directory or dir (string) [no default]
- Name of the working directory from which to access the restart files. If not specified, the name of the current working directory is used. An absolute or relative path to the working directory of the previous run is allowed. The path should be surrounded by quotes in the input deck.
- from_run or run (integer) >=0 [=0]
- Run ID from which to restart the problem. If 0, the program restarts from the latest available run.
- from_time_step or step (integer) >=0 [=0]
- Time step from which to restart the problem. If 0, the program restarts from the latest available time step.
- reset_time_step (boolean) [=off]
- Flag specifying whether to reset the time step and time to zero.
- reset_time_increment (boolean) [=off]
- Flag specifying whether to reset the time increment.
- type (enumerated) [=incremental]
- Type of restart to perform.
- incremental
- Performs an incremental restart where all settings from the previous run are retained with the exception of those that are present after the RESTART{} command in the input file that is being processed.
- full
- Performs a full restart where no commands from the previous run are retained. The only data that is carried forward across the restart is solution data associated with nodal results, rigid bodies, flexible bodies, and so on. When using this type of restart, the input file must contain a fully populated set of commands followed by the RESTART command.
RESTART { }loads in the restart data of the last time step of the last run of the current problem in the current working directory.
The from_problem parameter specifies the name of the problem from which to restart. If it is unspecified, the name of the current problem is used. The current problem name is provided by the command line option, problem; see the AcuSolve Programs Reference Manual for a description of command line options.
The from_directory parameter specifies the working directory of the problem from which to restart. This directory may be either relative to the current directory or an absolute address. If the from_directory parameter is unspecified, the working directory of the current problem is used. This directory is given by the command line option working_directory; see the AcuSolve Programs Reference Manual for a description of command line options.
Every time the solver is run, a new run identification number is assigned to the problem. Within each run there might be one or more restart time steps. The from_run and from_time_step parameters are used to load the appropriate restart data. If both parameters are non-zero, then the proper file is loaded. If the restart data for such a run and time step does not exist, an error occurs. One or both of these parameters may be set to 0, indicating the use of the latest values. To be specific, if from_run is non-zero, but from_time_step is zero, then the latest restart time step of the given run is loaded. If from_time_step is non-zero, but from_run is zero, the latest run ID with the given time step is loaded. If both parameters are zero, then the latest run with the latest time step is loaded. In all cases, if no restart data are found, an error occurs.
RESTART {
type = incremental
RUN { }Here, the latest restart data of the current problem is loaded. Then the data are prepared for the solver by the RUN command.
Once the restart data are read, one or more problem parameters may be changed. In principal, all parameters may be changed at the restart, with the exception of the number of nodes given in the nodal coordinates.
RESTART {
type = incremental
TIME_SEQUENCE {
staggers = { "temp" }
STAGGER( "temp" ) {
equation = temperature
RUN {
}The RESTART command sets the unknown nodal fields to those written by the RESTART_OUTPUT command.
RESTART {
type = incremental
NODAL_INITIAL_CONDITION( temperature ) {
nodal_values = Read( "temp.new" )
RUN {
}replaces the restart temperature values with those in the file temp.new.
Setting reset_time_step to on sets both the step number and time to zero. The default behavior is to use the step number and time from the previous solution.
ANALYSIS {
title = "test problem"
type = transient
EQUATION {
flow = navier_stokes
turbulence = spalart_allmaras
AUTO_SOLUTION_STRATEGY{
initial_time_increment = .001
min_stagger_iterations = 2
max_stagger_iterations = 3
COORDINATE{
coordinates = Read("MESH.DIR/testModel.crd")
SIMPLE_BOUNDARY_CONDITION("wall"){
RESTART{
type = full
reset_time_step = on
reset_time_increment = on
RUN {}RESTART {
type = incremental
EQUATION{
species_transport = advective_diffusive
AUTO_SOLUTION_STRATEGY{}
NODAL_INITIAL_CONDITION( species_1 ) {
default_value = .5
SIMPLE_BOUNDARY_CONDITION("Inflow"){
species_1_type = value
species_1 = .25
RUN {
}You should also bear in mind that if you modified any of the commands resulting from the issuance of AUTO_SOLUTION_STRATEGY in the initial run, you must also do so in the restart file. Otherwise, the issuance of the AUTO_SOLUTION_STRATEGY command in the restart file will overwrite the values that were modified in the original run.
