udfGetNbcAuxIds()
Return the nodal boundary condition user auxiliary node numbers.
auxNodeIds = udfGetNbcAuxIds( udfHd ) ;
AcuSolve User-Defined Nodal Boundary Condition
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- auxNodeIds (Integer*)
- Pointer to two dimensional integer array of user auxiliary node numbers. The first (fast) dimension of the array is the number of nodes, nItems, and the second (slow) dimension is the number of auxiliary nodes, nAuxs.
Integer* auxNodeIds ;
Integer usrAuxNode0, usrAuxNode1, usrAuxNode2, node, aux ;
udfCheckNbcNumAuxs( udfHd, 3 ) ;
for ( node = 0 ; node < nItems ; node++ ) {
usrAuxNode0 = auxNodeIds[0*nItems+node] ;
usrAuxNode1 = auxNodeIds[1*nItems+node] ;
usrAuxNode2 = auxNodeIds[2*nItems+node] ;
}Errors
- This routine expects a valid udfHd.
- This routine may only be called within a Nodal Boundary Condition user function.
- The corresponding command must have a valid auxiliary_nodes parameter.
