ufpGetParticleData()
Get the array of particle data.
data = ufpGetParticleData( ufpHd, dataName ) ;
AcuTrace User-Defined Function Particle Routine
- ufpHd (pointer)
- The opaque handle which was passed to the user function.
- dataName (integer)
- Symbolic name of the requested data.
Table 1. Symbolic Name Data returned Array size UFP_PARTICLE_ID particle id 1 UFP_PARTICLE_MARKER marker 1 UFP_PARTICLE_POSITION position 3 UFP_PARTICLE_VELOCITY velocity 3 UFP_PARTICLE_LENGTH stretch vector 3 UFP_PARTICLE_MASS mass 1 UFP_PARTICLE_DENSITY density 1 UFP_PARTICLE_RADIUS radius 1 UFP_PARTICLE_VOLUME volume 1
Return Value
The return value is a pointer to a one-dimensional real array.
The size of the array depends on the value of dataName.
Particle user defined equation data is not accessed by this routine but instead by ufpGetUdfData.
Real *pCrd ;
pCrd = ufpGetParticleData( ufpHd, UFP_PARTICLE_POSITION ) ;
* Compute source term for residence time:
* Set source to 1 if the particle is in the residence box, 0 otherwise
if ( pCrd[0] >= xlo && pCrd[0] <= xhi &&
pCrd[1] >= ylo && pCrd[1] <= yhi &&
pCrd[2] >= zlo && pCrd[2] <= zhi ) {
outVec[0] = 1.0 ;
} else {
outVec[0] = 0.0 ;
}Errors
This routine expects valid ufpHd and dataName as arguments; invalid arguments return an error.
