Specifies a volumetric momentum source term to damp surface waves.
WAVE_DAMPING_SOURCE {parameters...}
Qualifier
This command has no qualifier.
- wave_damping_type
(enumerated) (=none)
- Type of wave damping to be applied. If none, no damping is
applied.
- none
- No damping.
- linear
- Linear damping model is applied.
- wave_damping_distance or dist real
(=0)
- Distance from the outlet surface where the damping source term is
active.
- wave_damping_coefficient or coef
real (=10)
- Coefficient multiplying the damping source term.
This command is used to damp a surface wave in a multiphase flow problem by adding
momentum source per unit volume to the momentum equation along the direction of
gravity. The momentum source per unit volume term takes the following form:
(1)
where C is the wave damping coefficient,
is the density,
is the velocity component along gravity,
x is the local coordinate where the source
term is being applied,
and
are the wave damping distance and the coordinate of
the outlet surfaces, respectively.
Wave damping with a linear model can be specified as
follows:
wave_damping_type = linear
wave_damping_distance = 5
wave_damping_coefficient = 10
Optionally, the outlet surface can be excluded from the damping zone calculation by
setting the boolean wave_damping to "off"
within the SIMPLE_BOUNDARY_CONDITION command.
