This file is required in order to calculate a solution. If you have generated an
input file but not run
AcuSolve, do not delete this file. Once a
solution is calculated, this file can be deleted, but will need to be recreated if you want
to recreate the solution.
The files in this directory are required in order to calculate a solution. If you have
generated an input file and created this directory, but not run AcuSolve, do not delete this directory. Once a solution is calculated,
this directory can be deleted, but will need to be recreated if you want to recreate the
solution. By default, the files in this directory will be ASCII files. You can change the preferences so that files created in this directory will be in
binary format ().
