Perform Parametric Trimming
Use the Split: Parametric tool to restore suppressed fixed points.
View new features for HyperWorks CFD 2022.
Discover HyperWorks CFD functionality with interactive tutorials and community resources.
Convert b-spline models to discrete models then clean up the geometry and mesh.
Review geometric errors in the model's surfaces and solids and fix any defects.
Explore the tools used to create geometry.
Explore the tools used to edit geometry.
Use the Split tools to create fixed points and split surfaces or solids using a variety of methods.
Use the Split: Interactive tool to quickly create fixed points on surfaces and edges, and split surfaces with lines. You can also remove fixed points from surfaces or surface edges to unsplit them.
Use the Split: Nodes tool to split surfaces using ordered (node list/path) and non-ordered nodes selections.
Use the Split: Lines tool to split surfaces and solids using lines, bounding lines, offset lines, and graphical lines.
Use the Split: Surfaces tool to split surfaces and solids using surfaces.
Use the Split: Planes tool to split lines, surfaces, or solids.
Split surfaces based on curvature or angle.
Use the Stitch tool to stitch and unstitch adjacent or overlapping surfaces, and suppress or unsuppress edges.
Use the Imprint tool to imprint geometry onto target surfaces or lines, thus creating new fixed points or edges.
Use the Drag/Spin tool to push or pull surfaces and spin lines and surfaces in order to creates surfaces or solids.
Use the Boolean tool to combine solids, subtract one solid from another, and find the intersection out of the solids.
Separate solids that are connected at a shared interface.
Use the Plug tool to find and fill cavities. The Plug tool can also be used to remove protrusions, holes, and complex features.
Use the Scale tool to resize geometry in your model.
Use the Mirror tool to mirror/reflect selected entities across a symmetry plane.
Use the Fuse tool to connect discrete topology surfaces/solids/parts. The Fuse tool can be utilized to connect close proximity inputs by defining a threshold.
Merge two or more solids or surfaces. Solids are merged by removing shared faces while surfaces are merged by suppressing shared edges.
Clean up problematic areas on geometry.
Set up the simulation model, materials, domains, and boundaries.
Define radiation conditions and create emissivity models.
Define direct, derived, and constrained mesh motion.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Define output conditions, run the simulation, and view the results.
Use the Template Manager to define rule-based logic for groups, geometric operations, and setup and automate simulation processes.
Post-process the simulation results by creating visualizations and measurements.
Click here to access AcuSolve online help.
ON THIS PAGE
ON THIS PAGE
