Export Files
In Engineering Solutions exporting various file types from the selected client to another format. The Export tab allows you to export a model to CAD line and surface data or finite element models.
During export you can write information from a HyperMesh database to many finite element formats. However, geometry data can only be written in IGES format.
Use the Custom option to export models using your own custom-built export translator, or export models using a translator provided with the HyperMesh installation but which is not directly accessible via the default Export pull-down menu.
The Export tab allows you to write information from a database to many finite element formats. However, geometry data can only be written in IGES format.
