Select a Loadcase
View new features for Engineering Solutions 2022.
Engineering Solutions is a modeling and visualization environment for NVH, Squeak and Rattle Director, Crash, CFD, and Aerospace using best-in-class solver technology.
Discover Engineering Solutions functionality with interactive tutorials.
Noise, Vibration and Harshness (NVH) is an important vehicle attribute that directly affects the customer experience.
Use Squeak and Rattle Director tool to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing tasks efficiently.
The Aerospace menu is a useful utility to build and view aerospace models.
Create an assembly structure from a .csv file definition.
Seamlessly process solver native results in HyperMesh. The File Loader is used to generate the new results entity.
Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
Enables exploring the element force and moment results (internal loads) from solver result files (grid point forces) for further component sizing/optimization tasks and also for component certification/margin calculation.
Calculate free-body forces, moments, displacements, and rotation.
Calculate the contribution of one or more elements to the force and moment equilibrium at desired nodes.
Define visualization options for the free-body plot.
Plot free-body forces and moments for the selected loadcase.
The FBD Forces tool can import or export one or more cross-sections using the .csv file format.
The FBD Forces tool can export one or more cross-sections using Nastran’s Monitor Point 3 Format (.bdf file).
Plot displacements and rotations at nodes.
Define a cross-section plane.
Display free-body forces and moments at each cross-section along a node path.
Potato plots are used to build load envelopes. VMT plots are used to build tensile, shear and bending moment diagrams.
Display normal and shear loads of panel structural members.
Display forces and moments acting on beam and bar elements.
In Nastran, the F06 file contains information related either to the diagnostic of the model, analysis check up and results. This tool enables you to parse a defined number of information blocks and store them as a HyperMesh table entity with a given name.
Use this tool to evaluate for the selected elements the average value of the selected result type.
Framework to plug certification methods inside HyperWorks to assess margin of safety from the model and result information.
Provides tools to create and manage connectors.
Provides functions to help you morph the shape of a finite element model.
Engineering Solutions Optimization technology is supported by OptiStruct.
Solver interfaces supported in Engineering Solutions.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
Setup an Optimization in Engineering Solutions.
