Create Mesh Quality Report
Create an HTML mesh quality report for the current model or for multiple models.
The standard HyperMesh criteria file is used as input. The mesh quality report summarizes the Quality Index (QI) calculations, along with information on the number of elements that fall into each QI range.
- A single summary HTML page that gives a brief summary of several key metrics for all selected models. This page links to pages with detailed information about the mesh quality of each model.
 - A directory containing HTML pages for each model. These pages contain detailed mesh quality information. This page contains a link to the input HyperMesh file as well as the criteria file used.
                From the menu bar, click  and select:
- Choose Current Model to create a report for the current model.
 - Choose Multiple Models to create a report for multiple models.
 - In the Browser for Folder dialog, select the output directory where the report will be located and click OK.
 - If you are creating a report for multiple Files, in the Select model file(s) dialog, select the database files to generate the report for and click Open.
 - In the Select criteria file dialog, select a criteria file and click Open.
If you are creating a report for the current model, when the current model is not saved as an .hm file, instead of using the HyperMesh model name in the HTML, the name CurrentModel is used. There is no link from the detailed report to the model file, as one does not exist.
