Define Representations
Create your own user defined representation. User defined representations are saved to the settings and will be available in subsequent HyperMesh sessions.
- In the Part Browser, right-click on part assemblies or parts and select from the context menu.
 - In the User Representation dialog, click + to add a new representation.
 - In the Representation field, enter a name for the representation.
 - In the Param File and Criteria File fields, select the appropriate mesh parameter and criteria file.
 - If the representation is for solids, select the Solid checkbox.
 - Click OK.
