names
Naming conventions used in various Model Verification Modules.
Settings
module
Name settings for the modules within Model Verification.
comparison-base
Identify FE Model in CAD-FE Comparison.
Supported values: “*base_model*”
spotweld
Naming pattern for component to be identified as spot weld component.
Supported values: “*-w-*”
part
Naming conventions for components.
connection
Naming convention for classifying the component as various connecting components.
bolt
Supported values: “*bolt*”, “!*plate*”
nut
Supported values: “*nut*”, “!*plate*”
clip
Supported values: “*clip*”
rivet
Supported values: “*rivet*”
stud
Supported values: “*stud*”
screw
Supported values: “*screw*”, “*scr*”
pin
Supported values: “*pin*”
arc
Supported values: “*arc*”, “*weld*”, “!*bolt*”, “!*nut*”
spot
Supported values: *spot*
other
Supported values: “*”, “!101-*”, “!102-*”, “!103-*”, “!104-*”
unwanted
Supported values: “f/j_boot”, “f/j_b/band”, “s/j_boot”, “s/j_b/band”, “*bane*”, “*cable*”, "*fulcrum*”, “*spring*”, “*surf*”, “*valve*”“*wstrip*”, “*zone*”
