Change the Attributes of an Axis
  1. From the Axis option menu, select Horizontal or Vertical (for xy plot and complex plot only).
  2. Select the axis name from the Axis list.
Or
  1. Select an axis from the current window.
  2. Right-click and select Edit to display the Entity Editor.
  3. Modify the attribute(s).
