Define the Display Attributes
  1. To change the line style and line thickness, select a curve or curves from the Available curves list.
  2. Under Display Attributes, select a line style and line thickness.
    The curve attributes change depending upon your selection.
  3. Click Use Preferences to use the preferences defined in the current session.
