Define Tip-to-Tail Function and Display Attributes
  1. From the Define Tip-to-Tail panel, under Based on, select All, Displayed or Selected for your selection method.
    All
    Bases the definition on all curves in the session. Manual selection of curves is not permitted.
    Displayed
    Bases the definition only on the curves displayed in the window. You can select curves manually. To remove a curve from the calculation process, select the curve(s) from the Available curves list and click the forward arrow, , to move the curve(s) to the Exclude column.
    Selected
    Bases the definition only on the curves that you select from the list.
  2. Once you've chosen your selection method, the tip-to-tail function is calculated and displayed on the polar plot.
