View new features for HyperGraph 2D 2022.
HyperGraph can read the following types of plot data files:
The user interface provides you with a consistent look and feel when you are working in any of the HyperWorks Desktop applications.
The HyperGraph 2D menus provide quick access to panels and tools.
The HyperGraph 2D toolbars provide quick access to commonly used panels and tools.
The Tab Area is the portion of the graphical user interface that contains the browsers, utilities, and other functionality not shown in the panel area.
The HyperGraph Plot Browser is located in the tab area sidebar and allows you to view the HyperGraph plot structure.
From the HyperGraph 2D NVH menu, the following options are available.
The Vehicle Safety Tools (VST) is a collection of over 200 macros, Templex functions, and external functions for use by a vehicle safety engineer.
Allows you to perform basic math operations on one, two, or three curves at a time.
The duration macro allows you to calculate the continuous duration for one or more curves.
Contains curve filtering functions, including Butterworth, FIR, and a new SAE 1995 that are not available to regular HyperGraph users.
The Injury menu offers calculations for all known injury assessment tools.
convert to/from common unit sets.
Contains some functions that are not commonly used, such as simulating a bar chart or histogram.
Provides several functions to calculate running statistics, regressions, FFTs, etc.
The Vehicle Safety Tools preference file contains templates to plot IIHS front intrusion and IIHS side structure intrusion plots for Radioss and LS-DYNA files.
The Pedestrian Impact tool facilitates the post-processing of pedestrian analysis.
The Compare Time History diagnostic tool consists of two pages. On the first page, the input data files, such as plot, result, and FE files, are selected. Page two contains the data needed to compare the reference files and comparison files.
Allows you to transform vector results from a time history or animation result files according to a coordinate system defined by three nodes from the same result file.
The MPDB tool offers a complete automated post processing solution of the MPDB Frontal Compatibility Assessment load case, for Radioss and LS-DYNA output files.
The Model Identification Tool, known as MIT, is a profile in HyperGraph 2D for fitting test data from frequency- and amplitude-dependent bushings to analytical models.
Discover HyperGraph 2D and HyperGraph 3D functionality with interactive tutorials.
Powerful data analysis and plotting tool for all types of CAE data.
HyperGraph 3D offers a 3-D plotting environment that is fully integrated with Altair Simulation, for managing, reviewing, and analyzing 3-D plots such as waterfall, surface, and 3-D line data.
Supported solvers in HyperGraph.
HyperGraph help for HyperWorks.
