Use the Continuous Duration Compression Macro
  1. From the Math menu, select One Curve > Duration > Duration Comp.
Or
  1. From the Plot Macros panel, select Continuous duration compression from the Macro list.
  2. Select the curve(s) for which you would like to calculate the continuous duration.
  3. Click Apply.
