Rotate a Graphical Object Using the Transform Tab
During transformations, you can select multiple objects and transform them simultaneously.
  1. From the Add Object panel, select an object from the Add Objects list.
    Tip: You can also click on the object in the modeling window.
  2. Click the Transform tab.
  3. Under Rotate, enter the rotational delta values for RX, RY, or RZ.
  4. Select an axis of rotation (RX, RY, or RZ), if necessary.
  5. Press the + or - buttons to rotate the object.
