hm_attributeindexbehavior
Returns the behavior flag of an indexed attribute on an entity.
hm_attributeindexbehavior entity_type entity_name_or_id attribute_index ?search_type?
HyperMesh Tcl Query Command
- entity_type
 - The type of entity to query.
 - entity_name_or_id
 - The name or ID of the entity.
 - attribute_index
 - The index of the attribute owned by the queried entity (starting at 1).
 - search_type
 - By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
To get the attribute behavior of the attribute with index 3 on material 6:
hm_attributeindexbehavior material 6 3 -byid
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
