hm_attributeindexidentifier
Returns the identifier flag of an indexed attribute on an entity.
hm_attributeindexidentifier entity_type entity_name_or_id attribute_index ?search_type?
HyperMesh Tcl Query Command
- entity_type
 - The type of entity to query.
 - entity_name_or_id
 - The name or ID of the entity.
 - attribute_index
 - The index of the attribute owned by the queried entity (starting at 1).
 - search_type
 - By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
To get the attribute identifier of the attribute with index 3 on material 6:
hm_attributeindexidentifier material 6 3 -byid
   # Handle error
