hm_comparereturnresults
shortDescription
hm_comparereturnresults ?source_component_id? ?target_component_id?
HyperMesh Tcl Query Command
longDescription
The output is a list of lists.
  1. Consolidated compare data of all sources (Matched Overlapped Intersected Unmatched)
  2. Consolidated compare data of all targets (Matched Overlapped Intersected Unmatched)
  3. Consolidated matched/overlapped/intersected/unmatched data of one source or target (0|1 CompID CompareType MatchPercentage)
    1. 0 indicates source, 1 indicates target
  4. Fragmented matched/overlapped/intersected/unmatched data of one source with one target (0|1 SourceCompID TargetCompID CompareType MatchPercentage)
    1. 0 indicates the next list has target entities, 1 indicates the next list has source entities
  5. Information on component ID and type Entities of source or target and match type as determined in the list 4 ( SourrceCompID SourceType TargetCompID TargetType)
  6. Entities of source or target and match type as determined in list 4 (EntityIDs)
The data repeats from list 3 to list 6.
source_component_id
If ignored, or set to 0, all the compared data corresponding to all source components will be generated. If a valid source ID is given, the compared data for the corresponding source component is generated.
target_component_id
If ignored, or set to 0, all the compared data corresponding to all target components will be generated. If a valid target ID is given, the compared data for the corresponding target component is generated.
Examples
Compare assembly 1 to assembly 2 and get results for source component 12 and target component 14:
*createmark elems 1 "by assems" 1
*createmark elems 2 "by assems" 2
hm_compareinit
hm_comparesetflags 1
hm_compareentitiessameside elems 1 elems 2 1.0 2 0
hm_comparereturnresults 12 14
hm_compareend
   # Handle error
Version History
2020
