hm_ce_fe_config
Gets the weld config defined for the connector.
hm_ce_fe_config ce_id type_or_name
HyperMesh Tcl Query Command
ce_id
The ID of the connector.
type_or_name
Flag to return number ( = 0) or name (= 1).
To get the config for the last connector created:
set ce_id [ hm_entitymaxid CONNECTORS ];
set type_or_name 0;
set config [ hm_ce_fe_config $ce_id $type_or_name];
Returns the weld config stored for connector realization. To get the name of the weld configuration, use flag as 1.
None.
