hf_getdrawbeadforce
Calculates and returns the draw bead forces.
hf_getdrawbeadforce material_name thickness height radius shoulder_radius friction type
HyperMesh Tcl Query Command
This command returns the locking condition, restraint force, closure force and final force.
material_name
Name for the material
thickness
Blank thickness
height
Draw bead height
radius
Draw bead radius
shoulder_radius
Shoulder radius
friction
Friction
type
Shape type:
1 - round
2 - step
3 - square
set returnValue [hf_getdrawbeadforce "CRDQ" 1.0 1.0 6.25 6.25 0.125 1]
set locking [ lindex $ returnValue 0 ]
set restraint [ lindex $ returnValue 1 ]
set closure [ lindex $ returnValue 2 ]
set final [ lindex $ returnValue 3 ]
   # Handle error
