hm_findpolygonselection
Finds a polygonal path that connects all given input elements. This path takes into consideration the local mesh flow when defining a polygon.
hm_findpolygonselection element_id1 element_id2 element_id3 ... ?element_idN?
HyperMesh Tcl Query Command
Finds and returns a closed path of elements connecting all given ordered list of input elements. The path tries to be polygonal with respect to local mesh-flow. The order of input is honored when constructing the path. A minimum of three element IDs needs to be provided to construct the path.
The command returns three lists of element IDs:
  1. Elements that form a path starting from the first element and ending at the last element, going through the rest of the input elements intermediately, in order.
  2. Elements that form a loop-completing path starting from the last element to the first element. This path, along with the one formed by the first list, forms a closed loop.
  3. Elements that form the filled selection. This includes the boundary elements on the loop and those that are “inside” the closed loop formed by the previous two lists.
element_id1
The ID of element 1.
element_id2
The ID of element 2.
element_id3
The ID of element 3.
element_idN
The ID of element N.
Examples
To highlight the polygonal path and lowlight the internal filled elements:
set out [hm_findpolygonselection 45527 45528 45519]
*createmark elems 1 {*}[lindex $out 0]; # loop elements
*appendmark elems 1 {*}[lindex $out 1]; # loop completion elements
*createmark elems 2 {*}[lindex $out 2]; # filled loop
hm_highlightmark elems 2 low; # lowlight loop fill elements
hm_highlightmark elems 1 high; # highlight loop elements
   # Handle error
Version History
2021.2
