hm_ce_type
Returns the type of a connector entity.
hm_ce_type id
HyperMesh Tcl Query Command
Return values include point/node, line, seam and area.
id
The ID of the connector to query.
To get the type of connector ID 2:
hm_ce_type 2
   # Handle error
