hm_getqephtimestep
Returns the time step calculated from QEPH elements in a component.
hm_getqephtimestep name
HyperMesh Tcl Query Command
This command returns the time step calculated from QEPH elements in a component.
name
The name of the component
To get the time step from component named "Flange":
hm_getqephtimestep "Flange"
   # Handle error
Version History
11.0.130
