hm_ce_getlinkentityinfo
Returns specific entity information for a connector.
hm_ce_getlinkentityinfo id index
HyperMesh Tcl Query Command
This command returns specific entity information such as entity type, entity name/ID, entity meshed state and re-connect rule. The values are returned as a list in the order type, info, state, rule.
id
The ID of the connector.
index
The link index into the connector.
To get entity information for connector ID 1 for all links:
set ce_id 1
set num_ents [hm_ce_numlinkentities $ce_id]
for {set count 0} {$count <= $num_ents} {incr count} {
  foreach {type info state rule} [hm_ce_getlinkentityinfo $ce_id $count] {
    lappend linkArray($type) $info
   # Handle error
