hm_getlinetgstartpoint
Returns the components of the tangent vector and the angle between the tangent vector and the z-axis at the line start point.
hm_getlinetgstartpoint line_id
HyperMesh Tcl Query Command
Returns the components of the tangent vector and the angle between the tangent vector and the z-axis at the line start point. The first 3 return values are the tangent vector components, and the 4th return value is the angle.
line_id
The ID of the line.
To get the components of the tangent vector and the angle between the tangent vector and the z-axis at the start of the line with ID 341:
foreach {tg_x tg_y tg_z ang} [hm_getlinetgstartpoint 341] {}
   # Handle error
Version History
11.0
