hm_jobs_getJobStatus
Returns the present status of a job on a server.
hm_jobs_getJobStatus server_job_id
HyperMesh Tcl Query Command
Returns the present status of a job on a server. If the job is not available or has been terminated, an empty list is returned.
server_job_id
The server job ID returned after submitting a job that is to be queried.
To query job ID 122366.admin:
hm_jobs_getJobStatus 122366.admin
   # Handle error
Version History
14.0.130
