hm_findconnectedpatches
Returns patches of connected elements.
hm_findconnectedpatches entity_type mark_id
HyperMesh Tcl Query Command
Finds connected patches of elements and returns the elements in each connected patch as a list. For example:
{1 2 3 4} {5 6 7 8 9} {10 11}
entity_type
The type of entity to query. Only elements are currently supported.
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.
To get the connected element patches for the displayed elements:
*createmark elems 1 displayed
set conn_elem_lists [hm_findconnectedpatches elems 1]
   # Handle error
Version History
14.0
