hm_flangedetectionfindmates
Executes the flange mating tools.
hm_flangedetectionfindmates max_search_dist=<distance> min_search_dist=<distance> ?parameter1=<value1>? ?parameter2=<value2>? ... ?parameterN=<valueN>?
HyperMesh Tcl Query Command
Runs the flange detection mating functions for finding flanges mating 'groups'. This must be preceded by a call to hm_flangedetectionfindflanges.
max_search_dist and min_search_dist are mandatory. All other parameters are optional and have default values. Parameters can be specified in any order.
- max_search_dist=<distance>
 - The maximum distance for the proximity search.
 - min_search_dist=<distance>
 - The minimum distance for the proximity search.
 - mode=<value>
 - 0 - Perform flange-to-flange mating only (default)
 - percent_mate_area_tol=<value>
 - The minimum mating area percentage required for valid mating. Default value 0.1.
- search_scope=<value>
 - 0 - No filter (default)
Examples
To find 2D flanges from elements in all components, using a min width of 2, a max width of 20 and a feature angle of 20, and write out all flange details to a file named C:/temp/flanges.txt:
set flangesfile [open "C:/temp/flanges.txt" "w"]
*createmark comps 1 all
hm_flangedetectioninit comps 1
hm_flangedetectionsetparams min_width=2.0 max_width=20 feature_angle=20
hm_flangedetectionfindflanges 1
set n [hm_flangedetectiongetnumberofflanges]
if { $n > 0 } {
    puts $flangesfile "Number of flanges = $n"
    puts $flangesfile "Flanges details"
    for {set i 0} {$i < $n} {incr i} {
        puts $flangesfile "$i details = [hm_flangedetectiongetflangedetails $i]"
        puts $flangesfile "$i midline = [hm_flangedetectiongetflangemidline $i offset_dist=0]"
    hm_flangedetectionfindmates min_search_dist=0 max_search_dist=10
    set m [hm_flangedetectiongetnumberofmatinggroups]
    if { $m > 0 } {
        for {set i 0} {$i < $m} {incr i} {
            puts $flangesfile "$i = [hm_flangedetectiongetmatinggroupdetails $i]"
    } else {
        puts $flangesfile "Flange mates not detected."
} else {
    puts $flangesfile "Flanges not detected."
hm_flangedetectionend
close $flangesfile
   # Handle error
}Version History
2019
