hm_ce_findduplicates
Returns a list of connectors that are considered to be duplicates of other connectors, within a given tolerance.
hm_ce_findduplicates tolerance mark_id location_type
HyperMesh Tcl Query Command
tolerance
The maximum distance between connectors to be considered as duplicate.
mark_id
The ID of the mark containing the connectors to consider. Valid values are 1 and 2.
location_type
The connector location type. Currently only supported for "point".
To get all duplicate connectors within a tolerance of 0.05:
*createmark connectors 1 all
hm_ce_findduplicates 0.05 1 point
   # Handle error
