hm_entityminid
Returns the minimum internal ID in use for an entity type.
hm_entityminid entity_type ?recalculate?
HyperMesh Tcl Query Command
entity_type
The type of entity to query.
recalculate
An optional argument, indicating whether the minimum internal ID should be recalculated due to deleted entities. Valid values are:
0 - Do not recalculate.
1 - Recalculate (default).
To get the minimum internal ID for properties:
hm_entityminid props
   # Handle error
