hm_getoffsetZ0
Returns the offset Z0 value of the specified element.
hm_getoffsetZ0 elem_id
HyperMesh Tcl Query Command
This command returns the offset Z0 value of the specified element.
elem_id
The ID of the element to query.
hm_getoffsetZ0 100
   # Handle error
Version History
11.0
