hm_jobs_editServer
Edits an already existing server.
hm_jobs_editServer name new_name new_host new_port
HyperMesh Tcl Query Command
Note that the "local" server is not editable.
name
The name of the server to edit.
new_name
The new name of the server.
new_host
The new host/IP of the server.
new_port
The new port number on which the server will communicate.
To edit the server HWUL:
hm_jobs_editServer HWUL hwul 172.1.3.4 17084
   # Handle error
Version History
14.0.130
