hm_exportidmgr
Exports the ID manager rules to a CSV or XML file.
hm_exportidmgr filename format
HyperMesh Tcl Query Command
filename
The full name and path of the file to export.
format
0 - CSV
1 - XML
To output the rules to C:/temp/rules.csv:
hm_exportidmgr C:/temp/rules.csv 0
   # Handle error
Version History
14.0.120
