hm_getqualitycriteriastatus
Checks the status of the quality criteria.
hm_getqualitycriteriastatus elementsize
HyperMesh Tcl Query Command
elementsize
Checks to see if it matches the existing quality criteria. If 0 is specified, the mismatch is not evaluated.
The output uses the following values:
  • 0 - Good criteria - criteria exist and match with the specified element size (if it is being checked).
  • 1 - Criteria do not exist.
  • 2 - Bad (inconsistent) quality criteria.
  • 3 - Mismatch of the specified element size and the criteria.
None.
