hm_getincrementalname
Returns a unique incremental name from a specified base name and one or more entity types.
hm_getincrementalname entity_type_list base_name ?start_num? ?num_digits? ?separator?
HyperMesh Tcl Query Command
This command returns a unique incremental name from a specified base name and one or more entity types (for example, name1, name2, etc.). Multiple entity types might require the same name (generate comp/mat/prop with same name), so the returned name is unique across the specified entity types.
For entity types enabled for name pool, the command looks at the solver name and returns a unique incremental solver name.
- entity_type_list
 - A quoted list of entity types to consider for generating the name. A unique incremental name is found considering all of the specified types. Only named entity types are valid.
 - base_name
 - The base name to use for generating the incremental name. A blank string can be specified to just use the incremental ID as the name. Names with spaces must be enclosed in quotes.
 - start_num
 - An argument that specifies the starting number for generating the incremental name. Unless specified as 0, the increment counter always starts at 1. Valid values are:
 - num_digits
 - An argument that specifies the number of digits to use for generating the incremental number. If 0, use the minimum number of required digits (default). If the generated incremental number does not fit within the specified value, an error is returned.
 - separator
 - An argument that specifies the separator (delimeter) that will be appended between the base name and the number. Only valid when start_num is -1.
Examples
Assume a model has entities with the following names:
- 1
 - 2
 - 4
 - 5
 - my_name1
 - my_name2
 - my_name4
 - my_name5
 - my_names001
 - my_names008
- my_names001
 - my_names002
- my_names001
 - my_names009
The generated names for the examples are shown below the command.
To generate a name based off of components in the form N, where N is the incremental ID of any length, using the highest available incremental name:
hm_getincrementalname "comps" ""
      or
hm_getincrementalname "comps" "" -1
6
      To generate a name based off of components in the form N, where N is the incremental ID of any length, using the lowest available incremental name:
hm_getincrementalname"comps" "" -2
 3
      To generate a name based off of components in the form N, where N is the incremental ID of any length, using the lowest available incremental name starting from 0:
hm_getincrementalname "comps" "" 0
0
      To generate a name based off of components in the form N, where N is the incremental ID of any length, using the lowest available incremental name starting from 1:
hm_getincrementalname "comps" "" 1
3
      To generate a name based off of components in the form N, where N is the incremental ID of any length, using the lowest available incremental name starting from 4:
hm_getincrementalname "comps" "" 4
6
      To generate a name based off of components in the form N, where N is the incremental ID of any length, using the lowest available incremental name starting from 50:
hm_getincrementalname "comps" "" 50
50
      To generate a name based off of components in the form my_nameN, where N is the incremental ID of any length, using the highest available incremental name:
            my_name
      or
hm_getincrementalname "comps" my_name -1
my_name6
      To generate a name based off of components in the form my_namesNNN, where NNN is the fixed incremental ID length, using the highest available incremental name:
hm_getincrementalname "comps" my_names -1 3
my_names009
      To generate a name based off of components, properties and materials, in the form my_namesNNN, where NNN is the fixed incremental ID length, using the highest available incremental name:
hm_getincrementalname "comps props mats" my_names -1 3
my_names010
      To generate a name based off of components, properties and materials, in the form my_namesNNN, where NNN is the fixed incremental ID length, using the lowest available incremental name:
hm_getincrementalname "comps props mats" my_names -2 3
my_names003
      To generate a name based off of components and materials, in the form my_nameNNN, where NNN is the fixed incremental ID length, using the highest available incremental name:
hm_getincrementalname "comps mats" my_names -1 3
my_names009
hm_getincrementalname "comps mats" my_names -2 3
my_names003
   # Handle error
}Version History
11.0.130
2020 - Added new option separator.
