hm_markclear
Clear all entity IDs of the passed entity type from the specified mark.
hm_markclear entity_type mark_id ?panel_sensitive? ?model_name?
HyperMesh Tcl Query Command
This command clears all entity IDs of the passed entity type from the specified mark.
- entity_type
 - The type of entity mark to clear.
 - mark_id
 - The ID of the mark. Valid values are 1 and 2.
 - panel_sensitive (optional)
 - Can be used when multiple panel levels have been pushed, either using the shortcut function keys, or the hm_pushpanel command. This option determines whether to use the current panel or the previous panel for the operation. This option is relevant only when the mark has been created from a panel entity selector under the above conditions. Valid values are:
 - model_name
 - The optional model to clear the mark from. If not specified, the current model is used.
hm_markclear comps 2
hm_createmark comps 2 "advanced" "all"hm_markclear comps 2 0 model-2
hm_createmark comps 2 "by model" model-2 "advanced" "all"Errors
   # Handle error
}Version History
2020 - Added new option model_name.
