hm_entitiesassociatedbygroupsmark
Selects entities associated through groups.
hm_entitiesassociatedbygroupsmark entity_type input_mark_id output_mark_id ?group_mark_id? ?level?
HyperMesh Tcl Query Command
Selects entities associated to each other through groups.
entity_type
The type of entity to query. Valid values are nodes, elements and components (only elements in components are considered).
input_mark_id
The ID of the mark containing the input entities. Valid values are 1 and 2.
output_mark_id
The ID of the mark containing the isolated output entities which contains only nodes, elements and components. Valid values are 1 and 2.
group_mark_id
The ID of the mark containing the groups to consider for association. Valid values are 0 (default, meaning all groups), 1 and 2.
level
0 - No level down
  • Comps
  • Elems
  • Nodes
1 - One level done
  • Comps -> Elems
  • Elems -> Nodes
  • Nodes
2 - Two levels down
  • Comps -> Elems -> Nodes
  • Elems -> Nodes
  • Nodes
The reverse is performed on the output.
To find nodes, elems and comps associated to comps 1-5 by all groups:
*createmark comps 1 1-5
hm_entitiesassociatedbygroupsmark comps 1 2 0 2
   # Handle error
Version History
12.0.110
