hm_setmodelcheckresultentids
Sets the entity IDs for the specified Model Check check display name.
hm_setmodelcheckresultentids display_name mark_id
HyperMesh Tcl GUI Command
This command sets the entity IDs for the specified Model Check check display name.
display_name
The check display name.
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.
To set the entity IDs for the check named "Unused Materials" and to the entities stored on mark 1:
hm_setmodelcheckresultentids "Unused Materials" 1
   # Handle error
Version History
11.0.101
