hm_getmarkall
Returns a list of lists containing the populated entity type and entity IDs for the specified mark.
hm_getmarkall mark_id ?model_name?
HyperMesh Tcl Query Command
Returns a list of lists containing the populated entity type and entity IDs for the specified mark. The first value in each returned list is the entity type, and the remaining values are the entity IDs of that type. For example, if mark 1 is populated with elements 1-5 and comps 101-105, the returned values would be:
{elems 1 2 3 4 5} {comps 101 102 103 104 105}
mark_id
The ID of the mark to query. Valid values are 1 and 2.
model_name
The optional model to get all marks for. If not specified, the current model is used.
To find all of the entities on mark 1:
hm_getmarkall 1
To find all of the entities on mark 1 for model model-2:
hm_getmarkall 1 model-2
   # Handle error
Version History
11.0
2020 - Added new option model_name.
